2000 DTS
Service engine light came on, car seems to shake at idle and sputter when taking off, I am scheduled to get it scanned, I went to look for the plugs, cant find them, does anyone know where the spark plugs are located, and secon how do you know when your strter is going bad, i placed the key in the ignition and i get nothing, i wait like a few minutes, and the car starts right up, any suggestions
RE: 2000 DTS
royalet.... are you talking (2) two situations here?.......#1 engine not running so good, and#2"key in ignition, and nothing"...... does that mean your having trouble starting the car?...... question, when the car is running, are you having electric issues?..ie: wacky fuel gauge, instrument panel flicker, pwr windows, locks inop at times, stuff like that?......... give the Forum a little better info, so the Forum is able to help, or direct you...............
rickyd |
RE: 2000 DTS
ORIGINAL: royalet Service engine light came on, car seems to shake at idle and sputter when taking off, I am scheduled to get it scanned, I went to look for the plugs, cant find them, does anyone know where the spark plugs are located, |
RE: 2000 DTS
Thanks, well the 1ste issue is when i put the key in the ignition, i turn it, all i get is the radio, dash ect, but no crank , click or anything, and to answer the question about when the vehicle is running i dont have any problems with any of the electronics. 2nd the spark plugs, i guess when i remove the the top cover you have to halves, your saying the plugs are in the center of that
RE: 2000 DTS
ok i think i got what your saying, you said if i remove the valve cover i will see the plugs and coil packs?
RE: 2000 DTS
royalet......SPARK PLUGS....... follow the plug wires.........and dig!!!!................... there you go
rickyd |
RE: 2000 DTS
ORIGINAL: rickyd royalet......SPARK PLUGS....... follow the plug wires.........and dig!!!!................... there you go rickyd |
RE: 2000 DTS
I put green dots beside the bolts to unfasten. Plugs are under there.
[IMG]local://upfiles/2406/AED4CAE61287421BA9D35242704B6155.jpg[/IMG] |
RE: 2000 DTS
Hey Thanks alot I appreciate that, I did manage to get the car started i believe it was a loose connection over near thge fuse box, BUT i had the car diagnosed at autozone, and the thcode was something like P0202, cant recall but it said #2 fuel injector open circuit, does anyone know the location of the #2 fuel injector, and is this hard to do
RE: 2000 DTS
katzmans, royalet.....sorry, my 99 has the plug wires....woops
