1996 Seville water pump
I have a 1996 Seville, I'm trying to re-place the water pump is there a certain way to re-install the pump? Every time I put it back together the fluid pours out the back of the housing. I've replaced the o-ring, cleaned it out. Is there a certain way the clips on the water pump have to be in order to securely fit in the housing? Any help would be greatly appreciated.
RE: 1996 Seville water pump
Are you using special tool to install pump?
Yes, I'm using the special tool. One of the retaining tabs are different from the rest. Is there a certain spot in the housing for that tab?
Thanks for your reply. |
