'06 STS door lock- locksmith?
The driver's door on my 2006 STS will not unlock with the remote. Is this a issue that I can resolve with "personal settings". It could be a mechanical issue.. should I call a locksmith?
If i were at your place, i would immediately hire nearest locksmith near me to unlock it if the remote doesn't work.
Did the fob you're using previously work with that door and this is a new issue, or is it a new/replacement fob you're using? A new fob will need to be programmed to your specific vehicle by a locksmith. If its the same fob you've been using, it is likely a dead battery- however, if it works to open the rest of the doors I would think it must be a mechanical issue.
I had a similar problem a few months ago. But I was too naive and self-confident at first, so I decided to repair the door lock myself. But I didn't take into account that I knew nothing about it. So I guess I just made things worse. Then my friend advised me to make the car key replacement. Next time, if there'll be any problems, I won't try to deal with it by myself. Nothing can compare with the work of a professional, IMHO. BTW, does anyone have an automatic garage door? It seems to be very convenient. So I'd like to know your opinion on this point.
