05 Escalade Reverse Sensing Chimes
I have a 2005 Escalade and the Reverse Sensing CHimes stop working. The lights work, but the notification chime does not. Also, the seat belt warning chime is not working, for passenger or driver. Does anyone have an idea what this might be? Im sure they are related. They did work one time, then stopped again, and havent worked since. Their are no issues with my vehicle. It is in A1 shape (except for this). Thanks for your help.
@05Escalade, I have read your post about the chimes in your vehicle. On page 3-106 of the 2005 Cadillac Escalade owner's manual you will find the following information;
Chime Level Adjustment The radio is the vehicle chime producer. To change the volume level, press and hold pushbutton 6 with the ignition on and the radio power off. The chime volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold pushbutton 6 again. The chime level will change from the loud level to normal, and NORMAL will appear on the radio display. Each time the chime volume is changed, three chimes will sound as an example of the new volume selected. Removing the radio and not replacing it with a factory radio or chime module will disable vehicle chimes. If you have already attempted the above steps with your vehicle, I recommend contacting your local Cadillac dealership for diagnosis. Happy New Year! Michelle, Cadillac Customer Service |
Chimes
Hi thanks. What is push button 6? Is it the 6th cd button?
