02 Deville cuts off when idling
AAhhh, where to start....Well I just bought a 2002 Deville DHS Northstar with 79,600 miles on it. I got it home with no problems(FL to GA), and a couple of days later I got a service electrical and Service engine soon light. The car also started cutting off on me during idle (every other day)or just getting ready to leave idle. It starts right back up as though it never happened. Took the car in and only code found was a park lights error(they worked fine though). I have had the fuel system cleaned and serviced as well. I don't want to start replacing parts without having a clue as to what the real problem is. Also, not sure if this matters but my rpm is running at about 650 during idle. Any help would be greatly appreciated!!!!!
RE: 02 Deville cuts off when idling
One more thing...it has also done this while in Park.
ORIGINAL: janice29ga AAhhh, where to start....Well I just bought a 2002 Deville DHS Northstar with 79,600 miles on it. I got it home with no problems(FL to GA), and a couple of days later I got a service electrical and Service engine soon light. The car also started cutting off on me during idle (every other day)or just getting ready to leave idle. It starts right back up as though it never happened. Took the car in and only code found was a park lights error(they worked fine though). I have had the fuel system cleaned and serviced as well. I don't want to start replacing parts without having a clue as to what the real problem is. Also, not sure if this matters but my rpm is running at about 650 during idle. Any help would be greatly appreciated!!!!! the next time it cuts off, pull the codes on the spot. get it to us and we shall see what we can do. the how to do CODES is in the list but also check the others. The BEST car Cadillac ever made is the .. you get to pick. https://www.cadillacforum.com/m_9438/tm.htm MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars. https://www.cadillacforum.com/m_12353/tm.htm CODES .. Pulling & understanding CODES .. we need CODES to help you. https://www.cadillacforum.com/m_18197/tm.htm https://www.cadillacforum.com/m_17425/tm.htm https://www.cadillacforum.com/m_11904/tm.htm Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture, Corp 800 #’s, unique shipping services .. etc ... take a look. https://www.cadillacforum.com/m_9880/tm.htm Average age of our Cadillac owners .. where everyone says they are 23. https://www.cadillacforum.com/m_931/tm.htm Why you should change to coolant the day you buy the Cadillac. https://www.cadillacforum.com/m_7193/tm.htm https://www.cadillacforum.com/m_7388/tm.htm Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains. https://www.cadillacforum.com/m_6036/tm.htm Cadillac GM e-ghosts electric problems, intermittent codes, etc. https://www.cadillacforum.com/m_6068/tm.htm Help from our TECHs ? You really want to read this. https://www.cadillacforum.com/m_9792/tm.htm Cadillac TECH FAQ MENU .. pull up all the FAQ topics https://www.cadillacforum.com/m_6733/tm.htm Cadillac Technical FAQ section .. everything Cadillac https://www.cadillacforum.com/forumid_64/tt.htm Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc. https://www.cadillacforum.com/forumid_83/tt.htm The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in. https://www.cadillacforum.com/m_21055/tm.htm Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle https://www.cadillacforum.com/m_18287/tm.htm Hobby Corner .. Hot wheels, trains, whatever .. https://www.cadillacforum.com/forumid_60/tt.htm Cadillac History .. The real McCoy, from day one. https://www.cadillacforum.com/m_6356/tm.htm Welcome to CadillacForuM.com |
Here is the code I got....IPM B0429 Current. Looked this up and it was Temp control #3 Rear Circuit Range Performance. No other codes, so I am at a loss.
ORIGINAL: janice29ga Here is the code I got....IPM B0429 Current. Looked this up and it was Temp control #3 Rear Circuit Range Performance. No other codes, so I am at a loss. That cant be the cut out problem. Clear the codes and pull codes when it cuts out. did you do that? BTW, #1 suspect is the coil pack. Did you take the car through a car wash? rain? engine detail? |
I did clear out all codes, and when it cut off on me at a stop light I checked the codes. Luckily no one was behind me.[sm=smiley36.gif] I do run the car through the car wash though, but no engine detail. I suspect that the dealer had that done, as the engine looked as though I could have eaten off of it.
Well there are a few things that can cause an engine start the stop condition. As Stomp says number one on my list is electrical:
1. Loose or faulty electrical conections at coil pack or alternator or dampness or faultyignition parts.(wires, plugs, coil) 2. poor fuel delivery to injector rail, could be clogged fuel filter. 3. vac*** leaks in gaskets between intake plenum and throttle body 4. restricted exhaust system, most likely a catalytic converter clogged. 650 rpm at idle iin Park is a bit low, should be 650 in gear with brake on, so another possible cause could be IAC, idle air control valve. You should also check air filter. Without seeing your car I tend to go with #1 on the list as most likely cause. |
I took the car to the dealership, and was told that my fuel pump assy needs to be replaced. The fuel pump sending unit isn't sending the correct amount of pressure?
That would be #2 on my list from above.
Well, this didn't work either. The car cut off on me again.
