traction control fails daily
I have had my 2000 deville into two differant mechanics and the problem still is not solved, time to roll up my sleaves. The dash codes are ABS C1295 history ( ABS ID 4714 ) and IPM BO 429 current ( IMP ID 7856 ). Anyone have an answer?
Abs still failing
Checked brake and turn signal lamps, all are LED. I'm trying to find out where all the computor moduals are located to check connections for corrosion or bad wires, I'm planning to clean and lube with electrical grease.
Did touch ever figure it out? I have led's too and have the same problem.
