History Codes
Old 06-27-2008, 08:02 PM
ronniels's Avatar
Default History Codes
Will any of these History codes keep the car from starting?
Thanks!
P0204 - Injector 4 Control Circuit
P0603 - Control Module Long Term Memory Reset
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
U1096 - Loss of Communications with IPC
U1088 - Loss of Communications with SDM
U1064 - Loss of Communications with DIM
Old 06-27-2008, 08:59 PM
carnut's Avatar
Default RE: History Codes
None that I see. These are history, not current. So erase them. Does the car, at this time, crank over and not start? Also list year and type of car in your profile signature.
Old 06-27-2008, 10:53 PM
ronniels's Avatar
It turns over, andI depressed the shrader valve and there is fuel pressure.
The battery is new and I made sure is was fully charged. Turns over fine.
I can not get to it this weekend, but I will go thru and check all connections and pull the plugs.
If I find anything I'll post the results.
Thanks!
1997 Deville
05-13-2018 08:20 AM
02-14-2011 11:58 AM
Virginia John
11-19-2007 10:29 AM
04-05-2007 06:16 PM
cadillac8170
07-21-2006 07:45 AM
Quick Reply: History Codes
