engine timing
It just dawned on me that i havent had the timing adjusted since ive had my car. Ive drove it about 35k miles. How often are you supposed to get the timing adjusted? Its a 89' Fleetwood 4.5 FWD. About how much does it cost to get the timing adjusted?
RE: engine timing
ORIGINAL: 1989 fleetwood It just dawned on me that i havent had the timing adjusted since ive had my car. Ive drove it about 35k miles. How often are you supposed to get the timing adjusted? Its a 89' Fleetwood 4.5 FWD. About how much does it cost to get the timing adjusted? if it passes the SMOG, LEAVE IT ALONE. The SMOG technician adjusts the timing as needed each time it goes in for test. |
RE: engine timing
Timing normally does not to be adjusted, only checked if there is a drivability problem.
RE: engine timing
oh i thought that the timing chain got worn out after a while. If its got a timing belt wont it go out after some time?
RE: engine timing
ORIGINAL: 1989 fleetwood oh i thought that the timing chain got worn out after a while. If its got a timing belt wont it go out after some time? Interpreted as: check it for slack and change it if worn. ITS NASTY when the chain goes and the engine is doing rpm's. That is not what ignition timing is for. |
