davemr |
08-06-2012 01:39 PM |
Engine overheat.
Had a 2000 Deville, was using oil, not leaking oil. DOBBs tire and auto said this was normal, no problem. Then had radiator leak with engine over heat. Dobbs replaced radiator and hoses. On drive home from DOBBs, car overheated again and took back to DOBBs. They said no problem. just air in system. Took car on trip and was stranded on side of highway withover heated engine that would not cool down. Abandoned car and got new one. am wondering what the likely cause was and should DOBBs have known more troubles could be on the way after innitial overheat?
