65 Super Nova
http://s3.racingjunk.com/ui/9/06/480...Super-Nova.jpg
1965 Chevy II SUPERNOVA Test Hit: https://youtu.be/GG4avUQXyGc $28K CASH FIRM!!! or trade + $15K cash min. Body: ALL STEEL CAR Except Hood , ALL Windows and Glass Work Great , Nice Factory Dash , Factory Tach Still Present.. BEAUTIFUL PERFECT PAINTWORK !!!!!!!!!!! SUSPENSION / BRAKES: -- Back Half & Front chassis: 2x3 Full ALSTON, Orig. factory Floors still present , w Motor plates, Nice and clean $4950 -- Rear End: is 9" Ford , MOSER Center Section, Billet Pinion support . 5.13 gear , 35 Spline Axles , ART MORRISON Ladder Bar Set Up With support. Chassis Works $1159. Backhalf, Ford 9” $920, Moser Pumpkin $1275. -- Rear Coil Overs QA1 Adjustable, $240. -- Brakes: 4 wheel WilWood Disc Brakes , Aluminum Master Cylinder.. $2300. (all 4) -- Front Coil Overs Adjustable KONI, STRANGE Rack & Pinion Steering, Cromoly Tubular A-Arms . $240. POWERTRAIN: ENGINE: -- SHAFIROFF 434c.i. MERLIN Block ... ( Engine/Trans. ALL New with "8" Test & Tune passes - 1/8th mile.. ) -- Pistons: JE $14,700. -- Balancer: ATI $230, -- Intake: Bowtie, P# 10185053 NAScar -- HEADS: GM BOWTIE (363 Hi-Port ) 18 Degree HEADS (Ported) ,2.18 Titanium Intake Valves , All JESEL Valve train / Rockers ., Comp OffSet Roller Lifters . $came with Motor -- CAM: 7/4 SWAP Comp Cam , $ Came with motor -- Bearings: Roller Cam, Bronze Lifter Bores , $ Came with Motor -- CARB: RUPPERT 1050 cfm Alcohol $1005. -- Fuel Pump: AEROMOTIVE 2000, incl. AN $650 -- Headers: STAHL Custom Built, Fender Exit headers $975. -- Fuel Cell: 7 Gal. $65 Sender, $29 -- Water Pump: MOROSO Electric, $185. -- Vacuum Pump: MO... $32,000 Posted by: dz8190 Location: WELLSBORO, PA Post Date: June 30, 2017 Expires: October 20, 2017 More... |
