1967 Impala - 604 CI, fuel injected
1967 Chevrolet Impala
Motor:
- Dart Race Series Big Block Chevy Tall Deck Cast Iron
- Oliver BBC Connecting Rods
- Lunati crank; balanced
- Static compression ratio: 13.2 to 1
Heads
- AFR 357cc BBC Rectangle Port Cylinder Heads
Valvetrain
- Jesel Shaft Mount rocker system
- Jesel Sportsman Series 1.7 ratio rocker arms (KSS-18707)
- Comp Cams Solid Roller Cam
- Comp Cams Endure-X Solid Roller lifters
Ignition
- F.A.S.T. EFI, w/dual sync distributor
- Xceldyne BBC Pro Series Belt Drive
- Full complement of fuel injector sensors (Air fuel, Coolant, Air temp, Idle Air Control, etc.)
Vacuum pump
- Star
Chassis: Designed and built by Marty Danko (MD Racing, Warminster, PA)
- Backhalved, round steel
- Rollbars connect “through” the rear seat speaker grill; grill modified for the bars (back seat available and can be installed)
- Double adjustable ladder bar
- QA1
Oil Pan:
- Stef’s BBC
Intake :
- Victor Jr, modified by for fuel injection
- 2000 CFM Dominator-style throttle body
Body:
- Fenders tips were recently repaired; fenders are now solid and ready for paint
- F...
$28,000
Posted by: hpcampbell
Post Date: September 16, 2017
Expires: January 6, 2018
More...
Sonny1976
Vintage & Classic Cadillacs
01-18-2009 04:13 PM
allenpinney
02-16-2008 07:03 PM
57Caddy57
03-11-2007 04:11 PM
