1967 Impala - 604 CI, fuel injected
https://s3.amazonaws.com/s3.racingju...l-injected.jpg
1967 Chevrolet Impala Motor: - Dart Race Series Big Block Chevy Tall Deck Cast Iron - Oliver BBC Connecting Rods - Lunati crank; balanced - Static compression ratio: 13.2 to 1 Heads - AFR 357cc BBC Rectangle Port Cylinder Heads Valvetrain - Jesel Shaft Mount rocker system - Jesel Sportsman Series 1.7 ratio rocker arms (KSS-18707) - Comp Cams Solid Roller Cam - Comp Cams Endure-X Solid Roller lifters Ignition - F.A.S.T. EFI, w/dual sync distributor - Xceldyne BBC Pro Series Belt Drive - Full complement of fuel injector sensors (Air fuel, Coolant, Air temp, Idle Air Control, etc.) Vacuum pump - Star Chassis: Designed and built by Marty Danko (MD Racing, Warminster, PA) - Backhalved, round steel - Rollbars connect “through” the rear seat speaker grill; grill modified for the bars (back seat available and can be installed) - Double adjustable ladder bar - QA1 Oil Pan: - Stef’s BBC Intake : - Victor Jr, modified by for fuel injection - 2000 CFM Dominator-style throttle body Body: - Fenders tips were recently repaired; fenders are now solid and ready for paint - F... $28,000 Posted by: hpcampbell Location: HADDON HEIGHTS, NJ Post Date: September 16, 2017 Expires: January 6, 2018 More... |
