xlr hack code
i had the original dvd/nav unlock code of 1791, it only worked for a day or so,
now it won't. anyone have the right code, where i can buy some sort of module (not suncoast), or why the code no longer works? |
RE: xlr hack code
go to a side mechanic and he willl do it for you for cheap the problem is that you can freeze the navigation up and it will have to be ripped out of your vehical not wise to do at all.
RE: xlr hack code
do what for cheap, i'm not sure if you mean a code or what?
RE: xlr hack code
the code or even theirs a bypass system that you can purchase.
RE: xlr hack code
where can i get this bi-pass from, and do you know anyone in Mn that could install it?
RE: xlr hack code
Go to a Ghetto mechanic or go to a Cadillac dealership and tell them what you want and they will help you get it. every state is different. tip a mechanic on the side to do it for you..
RE: xlr hack code
call me and ill tell you more
RE: xlr hack code
there are things that GM doesnt allow, officially. then there are also things the mechanics know about that but is not allowed but works. these cannot be done within the dealer's system, but .. .. some mechanics "moonlight" their knowledge OFF-DUTY. hope that helps |
Cheap drugs
Drugs
