Transmission Replacement
I'm going to be replacingthe transmission in my '94 STS. Appears that it is a 4T80E transmission. Any reason a 4T80E transmission from any other year Seville or other Cadillac which has a 4T80E will not fit and work?
RE: Transmission Replacement
Check with the dealer or bone yard for which years and modleswill interchange.
A 2005 4t80e will not work properly with a 94 sts PCM. The biggest difference i know of is the TCC changed around 2000. There will be other changes through the years so you need to do your homework before you make the swap. |
Thanks for the response. I have found out that the 94 STS 4T80E was a one year one year only STS tranny. Different wiring harness and various other items. Going to rebuild the one I have.
