Side mirror's
I have a 1998 STS with curbview mirror assist, and the problem is that everytime I get into my car to drive it I have to reset my mirror's.....which is a major pain in my a%%. I have programed the settings for driver 1 and 2, but neither side mirror's go back to what I had set. Does anyone know if the motor'sact up overtime or has anyone had the same problem?? etc... I am ready to just set them and pull the circuit breakers if that's what I need to do? or can I disarm the system with out pulling circuit breakers. Please help -Brock-
RE: Side mirror's
Disable the reverse tilt funtion and see if that helps. July has been labeled "disable reverse tilt function month". Let us know the outcome. Thanks.
RE: Side mirror's
enable/disable on the MENU, under personal options or something like that.
RE: Side mirror's
Try this.....(this is going to be tough to explain) Which ever way they are off, take and reverse them till they dont go anymore and let them "click" some more.........??? do you follow what im trying to say? The gears that move them are not in sink, and that should aline them......Let me knowhow you make out
rickyd |
RE: Side mirror's
I have the exact problem. The mirrors are both changing postion on restart. I have rest both thru the drivers postion seeting. Seat and column are doing fine.
