leaky sunroof
Anybody deal with a leaky sunroof on a 93 Seville STS?
RE: leaky sunroof
IN MY EXPERIANCE,LITTLE AS IT IS. SUN ROOFS CAN NOT LEAK BECAUSE THEY ARE NOT SEALED. THE WATER IN YOU CAR IS CAUSED BY CLOGGED DRAINS. THERE ARE USUALLY FOUR, ONE AT EACH CORNER. TUBES COME DOWN AND EMPTY BY THE WHEEL WELLS.AIR FROM A COMPRESSOR INTO THE DRAIN WILL USUALLY CLEAR THE BLOCKAGE.A SHOP THAT IN STALLS AFTER MARKET ROOFS KNOWS HOW TO DO THIS, BUT MAY NOT WANT YOU TO KNOW IT IS EASY. GOOD LUCK
