How many miles?
I bought a 1993 STS that had 203,000 miles on it. It don't heat up and runs about 198 degrees, I only seen it at 201 degrees once and only uses about 1-1/2 qts of oil per 3000 mile change. It does have very clean green anti freeze in it and it runs very nice and smooth. My question is could I assume that the head qaskets were already replaced, could it possibly go that many miles without gasket replacement? If they were replaced and the head bolt kit installed are these engines good to go almost forever then? I really am surprised it don't need them and I bought this car expecting to have to replace them but maybe I got lucky.
Thank You |
RE: How many miles? 1993 Cadillac STS 203,000 miles
ORIGINAL: trikes I bought a 1993 STS that had 203,000 miles on it. It don't heat up and runs about 198 degrees, I only seen it at 201 degrees once and only uses about 1-1/2 qts of oil per 3000 mile change. It does have very clean green anti freeze in it and it runs very nice and smooth. My question is could I assume that the head qaskets were already replaced, could it possibly go that many miles without gasket replacement? If they were replaced and the head bolt kit installed are these engines good to go almost forever then? I really am surprised it don't need them and I bought this car expecting to have to replace them but maybe I got lucky. Thank You we have lots of 20 year old engines doing just fine, never having been opened .. but they all seemed to have ignored the GM 10 year thing and changed coolant often. check these valuable threads, special interest for you is the My Cad has more miles, headgaskets and coolant threads. The BEST car Cadillac ever made is the .. you get to pick. https://www.cadillacforum.com/m_9438/tm.htm MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars. https://www.cadillacforum.com/m_12353/tm.htm CODES .. Pulling & understanding CODES .. we need CODES to help you. https://www.cadillacforum.com/m_18197/tm.htm https://www.cadillacforum.com/m_17425/tm.htm https://www.cadillacforum.com/m_11904/tm.htm Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture, Corp 800 #’s, unique shipping services .. etc ... take a look. https://www.cadillacforum.com/m_9880/tm.htm Average age of our Cadillac owners .. where everyone says they are 23. https://www.cadillacforum.com/m_931/tm.htm Why you should change to coolant the day you buy the Cadillac. https://www.cadillacforum.com/m_7193/tm.htm https://www.cadillacforum.com/m_7388/tm.htm Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains. https://www.cadillacforum.com/m_6036/tm.htm Cadillac GM e-ghosts electric problems, intermittent codes, etc. https://www.cadillacforum.com/m_6068/tm.htm Help from our TECHs ? You really want to read this. https://www.cadillacforum.com/m_9792/tm.htm Cadillac TECH FAQ MENU .. pull up all the FAQ topics https://www.cadillacforum.com/m_6733/tm.htm Cadillac Technical FAQ section .. everything Cadillac https://www.cadillacforum.com/forumid_64/tt.htm Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc. https://www.cadillacforum.com/forumid_83/tt.htm The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in. https://www.cadillacforum.com/m_21055/tm.htm Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle https://www.cadillacforum.com/m_18287/tm.htm Hobby Corner .. Hot wheels, trains, whatever .. https://www.cadillacforum.com/forumid_60/tt.htm Cadillac History .. The real McCoy, from day one. https://www.cadillacforum.com/m_6356/tm.htm Welcome to CadillacForuM.com |
If you start adding up how many Northstars have been produced since 1993, thats 15 years, even if the number is 150,000 cars per year which is what one plant needs to be viable that is2,250,000 engines. You only hear about the ones that go bad. Have you heard two million stories?
