Help...stumped..."95 sts with turn/brake light problem
I have a 1995 sts. When the headlights are turned on, or sentenial on, the passenger side turn lights, front and back, do not work and the passenger brake light does notcome on. When the lights are turned off, all thesignal and brakelights work fine. Stumped as the problem is only on one side. The other turn signal and drivers side and trunk brake lightswork fine.
Have checked the 2 bulbs on the rear light and they seem okay..although the brake light is a little dimmer. Would appreciate any ideas on how to fix the problem. Love the Forum...got a terrific tip here on how to fix my ignition/security system problem when my car wouldn't startby cutting the wires at the base of the steering column and sodering in a resister. The best part was that the fixcost 2 cents. Thanks again. |
RE: Help...stumped..."95 sts with turn/brake light problem
welcome to the site ..
it is best to ask for help in the proper section .. member intro is not the place ... moving the thread for you ... |
