Can not open passenger door from outside
I have a 2008 STS. The rear passenger door can not be opened from the outside. I can open from the inside. Will not unlock using remote or driver control.
I have searched the forum and You Tube for how to test and replace a rear door lock module on my model Caddy... Lots of info on CTS , Nothing I can find on STS other than it ain't like the STS. I would greatly appreciate instructions on removing the lock module. Testing the existiing module The part number for the module Installing lock module A good supplier for this part. and if that ain't enough tonight the "Service Air Bag" alarm popped up Please help before anything else happens. |
Check loose connection under passenger seat. Separate and reconnect, make sure latches are secure.
