2006 STS4 Squeaking Sound when slowing
2006 Cadillac STS4 w/ Northstar V8
Discussion: When slowing or stopping there is a squeaking sound in the front suspension. Details: This is a very rickety sound much like what one is used to in an old pickup or work truck. The sound reacts when slowing down in a parking lot/garage as the car rolls over speed bumps. The sound goes away when the car is driven through a car wash with an undercarriage sprayer and sometimes in the rain. When the sound is audible it is coming from both sides of the front end. Troubleshooting up until now: Visual inspection -- I have visually inspected all of the front suspension from a-arms to shocks and all look normal w/o leaks or tears in grease joints. The car has slotted and drilled rotors -- I visually inspected the breaks as well as tearing them apart and cleaning all surfaces. (This noise was not apparent when I first installed the new brakes and factory pads) The research I have conducted shows that the control arms do go bad and have to be replaced, however, this noise is not a clunk and the joints all appear good. Ideas: I believe this to be a lack of grease in the anti-sway bar bushings. Before I tear the bushings off of the Cadillac I am open to comments and information from those who are/might be familiar with this issue. Please only respond to this post if you are familiar with this problem. Thanks, D. |
Hackneyd
I had the same problem on my 07 STS. I posted the problem back in Aug 08. It was a defective lower control arm. Bushings were shot. Car sounded like an old buggy going down the road. Eddiek |
Thanks Eddiek, the left lower control arm was the problem. I changed it out last weekend with a new part from GM, (P/N:25862781). This is an updated part from the original equipment and it looks like the busings have more material then that of the original's.
Here is the procedure for the lower control repair. Additionally you will need these tool sizes: 18mm socket and wrench 21mm socket (deep well) and wrench 24mm socket (deep well) Set of metric allen wrenches This article has been updated by TSB Bulletin No. 06-03-08-006 Date: May 17, 2006 SERVICE MANUAL UPDATE Subject: Revised Front Lower Control Arm Ball Stud Retaining Nut Fastener Tightening Specification Models: 2003-2006 Cadillac CTS, SRX, STS Lower Control Arm Replacement Tools Required
Strutmasters for your suspension problems
Take a look at Strutmasters conversion kits. These kits change your air suspension into a coil suspension. Best of all they come with a lifetime warranty. You want have suspension problems again.
Glad I could help. Based on the procedure, I'm glad mine was covered under warranty.
Eddiek |
