1996 STS blower motor not running
Blower motor stopped running all of a sudden. Followed by a burned wiring smell in the cabin. It had been acting up for several weeks. Would shutoff, or slow down, and then start back up. I checked the fuses and circuit breakers by switching a few around. They seem ok. I am leaning toward a burned out blower motor. Any suggestions on how to test it in car? Could it be something else? Thanks for any suggestions.
RE: 1996 STS blower motor not running
blower motor generally refers to the electric fan motor for the HVAC.
I'm think you are on the right track. I do a simply power and gound check at the motor with the a/c on. If you have both and the fan is not spinning well guess what. You need a new blower motor. The new ones come with an extra heat shield to help them last longer. |
Yes, simple power and ground check shows power to the fan motor. Of the 3 terminals, 1 had power, the other 2 did not. On the motor housing it reads "cut here for removal". What is that all about? I have not purchased a service manual yet, so I'm needing help with some of this research....thanks for your time.
