program keys and remote
Does anyone know how to progam keys and remote. I have 1 working key and 2 blanks which I had cut and all they do is unlock the door. Instructions that came with blanks said
1.insert programmed key and start car. 2. remove key and insert key to be programmed and turn to on position within 10 seconds. 3. security light will come on and will turn off when done. But when I insert the new key and set it to on the display reads " service theft system " I've tried with or without clearing the display but the key still wont work. I did this for about 10 min either way. I also have 1 working remote and would like to program the other. Any suggestions. |
RE: program keys and remote
ORIGINAL: 1stcaddy Does anyone know how to progam keys and remote. I have 1 working key and 2 blanks which I had cut and all they do is unlock the door. Instructions that came with blanks said 1.insert programmed key and start car. 2. remove key and insert key to be programmed and turn to on position within 10 seconds. 3. security light will come on and will turn off when done. But when I insert the new key and set it to on the display reads " service theft system " I've tried with or without clearing the display but the key still wont work. I did this for about 10 min either way. I also have 1 working remote and would like to program the other. Any suggestions. need more info on what you have .. car, model, year, etc. etc. also keys from whom? |
Hi Most remotes can be programmed manually at home without any tools or technical skills. If you need to just order the instructions please check our website at http://www.carandtruckremotes.com/pr...tructions.html If you have any more questions or have any specific inquiries about programming your vehicle please contact us at customercare@carandtruckremotes.com including year, make and model of your vehicle. You can also view our FAQ page for answers to common questions. Link below http://www.carandtruckremotes.com/faq.html Best Regards Customer Care http://www.carandtruckremotes.com http://www.newkeylessremotes.com http://www.keylessentrystore.com
For an SRX, you need the key/remote programmed by a Cadillac dealer.
