Changing the friggin' air filter!
I tried and failed changing the air filter of my '04 SRX. Any insight would be greatly appreciated.
RE: Changing the friggin' air filter!
The airfilter for the eng?? there are 2 screws on the top edge of mine. Remove the screws and tilt open the cover (helps if you slip the hose off the throttle body), you can pull the filter up and out. Then just drop in a new one (that reminds me I need to order a K&N for our SRX). Now if your talking about the Pollen filter (cabin airfilter) I have yet to remove that one, I've read that it can be a PITA.
Thanks for the reply...and yes it was my engine airfilter...i will give it a shot this weekend. Thanks again!
I do not recommend an oil wetted air filter element.
I don't like to re-wet 'em, they last a good while and then just tossit and get a new one. IMO.
ORIGINAL: ben721364 I do not recommend an oil wetted air filter element. |
So...did you ever get changed? Was the their a noticeable enhancement?
As well, for the other folks who indicated that an 'oil-wetted' air filter was not recommended...why? Are you saying it is not recommended in a re-use mode? |
ORIGINAL: brykerwoods So...did you ever get changed? Was the their a noticeable enhancement? As well, for the other folks who indicated that an 'oil-wetted' air filter was not recommended...why? Are you saying it is not recommended in a re-use mode? Adding oil may make matters worse. but if one does it once, properly, in 50,000 miles, who cares. |
