2015 SRX halogen headlamp with two min led lights.
What are the two little vertical led bulbs located within the the front headlamps called.
They're burned out on the right headlamp. Can they be replaced? What is the name for them if I want to order them. Thanks in advance! |
Did the housing fog up with moisture first? You may need to seal the things up with silicone first. If so you may want to dry everything off and try putting the bulb back in, or it could simply have burnt out? haha. What model do you have? the Premium used HIDs, would hate to give you the wrong info. (do some searches explaining your exact problem...)
EDIT: Oh, are you talking about the 'rope' lights? I don't know much about them but if they are LEDs i don't think they can burn out? Try drying them out and maybe sanding off connectors. AFTER checking the fuse, haah |
Finally a response!..yes its somewhat of a rope led light. Theres only two little led lights but its nice looking. Ill check the fuse...not sure which one to check....would there be a separate fuse for the two little LED lights. I have a base model..with halogen projectors...with the two led rope light that are located at the edge of the housing.
To my knowledge those LEDs hardly ever go out! You need to check other things like connections/fuses, etc... You never answered my question about the lens fogging up?
No sir..no fogging of the lights. It would seem I would have to pull out the entire Headlamp assembly to check the connection for those Led lights. Ill send a pic when I can.
I'm sorry you are not getting any response here. Sometimes it seems you get a better results when you ask stupid questions like what color interior should I get? But stick around...someone will know!
https://cimg2.ibsrv.net/gimg/www.cad...e6a58a1474.jpg
The bottom left two led lights aren't working on the other head lamp. Anyone know of the exact fuse number to check. 2015 srx. |
Most likely you are talking about rope LED lights. Try sealing the fuse first. It might be the problem. If it works, you might just be able to replace the two bulbs. But if the fuse is blown, there will be more fuss, so I suggest making sure there is nothing wrong with it first.
Better, of course, still look for accurate information on the net or consult with experts. Rope LED lights are not difficult to find. If they are just outdated, it is not difficult to order new ones. But often behind this is another problem, more seryoznye. So it is better to trust those who understand professionally |
