2010 exit assist problem
Hope you can help. I have the easy exit programmed and the configuration is on. The problem is that the seat goes back when opening the door but it does not go forward to the programmed setting when I get in.
Is there something I'm missing in the process? |
Check that you programmed it correctly. Also, do you use the remote to unlock the door? Mine works like this.
When I get out the seat goes to the exit position. If I use the remote to pop the door the seat goes to position 1 (driving). If the door was not locked and I open it without the remote, the seat stays in position 2 (exit). When I put the key in the ignition, the seat moves to position 1. RCAD |
RCAD
That is how my 2007 worked, but the 2010 does not have a key to put into the ignition, it has a start button on the dash which I really dislike. Bum |
Sorry, I forgot the 2010 has that dumb button. A friend of mine has a Nissan with that thing. One day he was at the mall and had to get something out of the car and he forgot without the fob in his pocket he could not get in the car. He had to go all the way back to get it from his wife who had it in her purse.
