Starting Problems!!!!!!!!Help!!!!!!!
[:@]I have a 95 sts, recently when I turn the ignition to the on position, the check engine light comes on, the screen reads traction disabled, and the cooling fans come on full blast,and the car won't start. The only way to start the car is to turn the ignition on and off several times until the check engine light doesn't come on, after that the car starts fine and runs like a top. None of the repair shops seem to know whats wronge with it, and the dealer wants $85 an hour just to check it out! So if anyone has had this problem please help.....thanks.
RE: Starting Problems!!!!!!!!Help!!!!!!!
get a code book and then presss the off and passenger heat at the same time and hold for 5 secs the info center will give you code #
ORIGINAL: muzik4life [:@]I have a 95 sts, recently when I turn the ignition to the on position, the check engine light comes on, the screen reads traction disabled, and the cooling fans come on full blast,and the car won't start. The only way to start the car is to turn the ignition on and off several times until the check engine light doesn't come on, after that the car starts fine and runs like a top. None of the repair shops seem to know whats wronge with it, and the dealer wants $85 an hour just to check it out! So if anyone has had this problem please help.....thanks. check these threads, there is probably most of what you need in there. The BEST car Cadillac ever made is the .. you get to pick. https://www.cadillacforum.com/m_9438/tm.htm MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars. https://www.cadillacforum.com/m_12353/tm.htm CODES .. Pulling & understanding CODES .. we need CODES to help you. https://www.cadillacforum.com/m_18197/tm.htm https://www.cadillacforum.com/m_17425/tm.htm https://www.cadillacforum.com/m_11904/tm.htm Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture, Corp 800 #’s, unique shipping services .. etc ... take a look. https://www.cadillacforum.com/m_9880/tm.htm Average age of our Cadillac owners .. where everyone says they are 23. https://www.cadillacforum.com/m_931/tm.htm Why you should change to coolant the day you buy the Cadillac. https://www.cadillacforum.com/m_7193/tm.htm https://www.cadillacforum.com/m_7388/tm.htm Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains. https://www.cadillacforum.com/m_6036/tm.htm Cadillac GM e-ghosts electric problems, intermittent codes, etc. https://www.cadillacforum.com/m_6068/tm.htm Help from our TECHs ? You really want to read this. https://www.cadillacforum.com/m_9792/tm.htm Cadillac TECH FAQ MENU .. pull up all the FAQ topics https://www.cadillacforum.com/m_6733/tm.htm Cadillac Technical FAQ section .. everything Cadillac https://www.cadillacforum.com/forumid_64/tt.htm Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc. https://www.cadillacforum.com/forumid_83/tt.htm The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in. https://www.cadillacforum.com/m_21055/tm.htm Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle https://www.cadillacforum.com/m_18287/tm.htm Hobby Corner .. Hot wheels, trains, whatever .. https://www.cadillacforum.com/forumid_60/tt.htm Cadillac History .. The real McCoy, from day one. https://www.cadillacforum.com/m_6356/tm.htm Welcome to CadillacForuM.com |
