Service Suspension System
I am getting the codes
RSS: C0640 current C0635 current C0710 current these codes are all occuring after recently replacing the EBTCM. Replacing the EBTCM got rid of the previous ABS codes that I had and replacing the CVRTD fuse got rid of "speed limited to 90", however now the RSS codes appeared. what could be a possible solution to this problem. Ive seen some posts speak of the steering wheel speed sensor or the ignition switch. any input would be greatly appreciated. I also have a replacement CVRSS module but that seems to not affect any of the current codes. |
what were the original codes
it almost sounds like the sensor at the bottom of the steering column here r a list of code meanings https://www.cadillacforum.com/forum/...ad.php?t=12013 |
