Service Stability System (What To Check)
It keeps happing again... I want all the options on where to stop so I know how to combat this. I have a 2000 STS.
RE: Service Stability System (What To Check)
I recently had the same issue (2000 SLS) and a new right rear hub along with a new abs sensor fixed it. I can check to see what the codes were if you would like to compare.
Good luck |
it is a known fact that the seville has had issues with tthe rear hub and abs sensor...i have a 2000 sls first the left one went then 8 months later the right one...very enoying if like me u dont have a warranty it is a expensive fix i did it myself and it costed me $365 for a new hub and 20 for a senor.Good luck.
