no ac
I pumped a couple of cans of R134 in to the system and it worked great for a day but the next day the R134 had leaked out and had on ac.I have a 2001 sevill sls and can't find the leak.dose anyone know the where the most comon leaks occur THanks randy.:confused:
you should try to get a can of R-134A with the dye and charge with that. then run it for a day. the next day, follow each of the A/C hoses with a blacklight and the leak will appear like magic. it cost a bit more than the regular R-134A but is awesome. or you could just get a bottle of dye by itself and use it later on to find other leaks in the vehicle. I would go the second route.
