99 STS electric problems
Old 02-10-2011, 11:48 AM
Bigv's Avatar
Default 99 STS electric problems
Please help if you can. Car has mind of its own at times. three times the alarm has gone off when trying to enter the car. used the key in the lock, ignition, and the remote to try to shut it off. Had to unhook neg. battery cable. Then its ok for a while. The latest thing is the battery is dead in the am. Something is running it down but can't tell what.
My gauge cluster also has been blacking out. Have to restart to get it to come back on, and the fuel gauge jumps full to empty.
Grateful for any help. GV
Old 03-02-2011, 07:46 PM
gmtechs's Avatar
check the battery connection for good contact
test the battery for bad cells
u need to do a parasitic drain test
is it an aftermarket alarm system
Old 03-04-2011, 06:37 AM
DJWerkz's Avatar
Is it a left-hand drive US vehicle or right-hand drive UK supplied vehicle?
If it's the latter it's more than likely a fault with the aftermarket (crappy) secondary alarm GM fitted to comply with UK insurance requirements when they were imported new.
These units are known to fail and you would be best to just disconnect it, it's fixed to the metal panel behind the rear seat (you have to remove the rear seat back to get to it). It's a small black plastic unit with a white multi-way connector and a positive and negative cable too, just disconnet all these cables and car will revert back to the original GM security system.
Remember, this only applies if it's a UK supplied right-hand drive vehicle.
Old 03-05-2011, 10:18 AM
Bigv's Avatar
Thank you for the replies.
No it is not an aftermarket security system. I will check on the drain test, and the battery cells.
It is a left hand US steering car. Thanks guys
06-29-2017 09:42 AM
Piper Mike
Non-V8 Engines
03-05-2015 06:01 AM
JokerRides
08-19-2013 03:39 PM
Shea_G
05-26-2009 08:03 AM
jheald
07-29-2008 06:43 AM
Quick Reply: 99 STS electric problems
