2003 STS Third Brake Light Puzzler
Old 05-03-2017, 04:40 PM
swvirgiian's Avatar
Default 2003 STS Third Brake Light Puzzler
A couple of weeks ago I noticed roughly 1/3 or maybe 1/4 of the lights in my third brake light were out on the far right side. I ordered a take-off from a 2003 STS, but a recent check of the original third brake light shows all the lights are lit, and all brighten when the brake pedal is applied. I would think if there's a short, all lights in the third brake light would be effected. Can anyone explain what might have happened to cause a contiguous portion of the third brake light not to work, and then function normally after a couple of weeks? Is it advisable to install the take-off recently purchased, or am I likely to see the same problem occur in time? Thanks for your help.
Old 05-04-2017, 03:50 PM
There is a narrow break in the circuit within lamp which depending on temperature connects and disconnects bulbs. Although I never tried it, I knew of people who took lamp a part and soldered circuit boards.
Old 05-05-2017, 09:25 AM
swvirgiian's Avatar
Default Circuit Boards Within 2003 STS Third Brake Light
Thanks for your reply, slowroll. Do you know if there are multiple circuit boards with the 2003 STS third brake light?
Old 05-05-2017, 03:15 PM
3 I think right left and center. bulbs are soldered in place also.
Old 05-06-2017, 08:30 AM
swvirgiian's Avatar
Thanks very much!
legalz
06-20-2023 07:04 AM
target08
05-12-2009 12:58 PM
Texan4Life
06-01-2008 08:04 AM
jono6406
02-13-2008 12:13 PM
tuttibear
08-15-2006 02:17 PM
Quick Reply: 2003 STS Third Brake Light Puzzler
