Coolant leak
I found the/a leak in the coolant system. The reservoir/overflow bottle was the culprit. There was some tiny pinhole leaks that only leaked when pressurized. So I cleaned up the area, sanded it down leaving a rough textured surface, then placed two layers of epoxy on the effected area.
Tomorrow, I might tackle the rear passenger door-it does not lock/window control/activate the alarm when opened.... I am hoping a connector/connection got knocked loose when I had that minor front collision... Kerry |
