Coolant leak
Old 10-20-2017, 05:24 PM
Kerry Phillips's Avatar
Default Coolant leak
I found the/a leak in the coolant system. The reservoir/overflow bottle was the culprit. There was some tiny pinhole leaks that only leaked when pressurized. So I cleaned up the area, sanded it down leaving a rough textured surface, then placed two layers of epoxy on the effected area.
Tomorrow, I might tackle the rear passenger door-it does not lock/window control/activate the alarm when opened.... I am hoping a connector/connection got knocked loose when I had that minor front collision...
Kerry
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
lferrebee
08-23-2007 04:36 PM
strabo40
12-11-2006 01:47 PM
mxblue23
03-13-2006 04:28 PM
mxblue23
02-28-2005 04:41 PM
Quick Reply: Coolant leak
