Change EGR on 96 Seville
Need to replace the EGR valve on a 96 Seville, and can't get the bracket holding the end of the fuel rail up far enough to clear the top of the EGR mounting stud. Is there a way to do this (I hope) without raising the entire fuel rail? Thanks to anyone that can help!
RE: Change EGR on 96 Seville
It should pull right up off the stud.
Try a large screw driver from underneth. It is a bit tight in there but I have removed many without loosening of the fuel rail. |
