Aftermarket Struts
I want to replace electronic Struts on my SLS with aftermarkets, I did this swap years ago on my 97 STS and it worked out nicely, used Power resistors to jump out the ride control sensors so as not to through a code.
What are the stiffest struts I can get for the Seville, are there any trure after market or is it more like putting a Deville strut on the front? Also does any one know the correct ohm Resistors for 2001 Thanks Guys for the Patience I haven't had my 1997 STS in about 3 years and I'm trying to remember everything but also have to familarize myself with the changes in the 2001 I have now. |
want to the the same to my 1997 Seville sts any details on the resister jump? ohm and where?
do you have the F55 system? If you aren't sure go into. the trunk spare tire cover and look for the suspension code.
