85 cadillac seville heater problem
my blower motor works when it wants to - it will be blowing and then it cuts out
then comes back on then goes out and sometimes wont at all this happen for both heat and cooling but cooling seems to act up more any thoughts |
Originally Posted by dunkinman9999
(Post 41432)
then comes back on then goes out and sometimes wont at all this happen for both heat and cooling but cooling seems to act up more any thoughts i be suspect of that specially if you notice that the acting up takes place when your car hits a bump in the road. . |
blower motor
Hi,i had the same thing.The blower motor speed is controlled by the ground of the motor,so check this first.I installed a 12 v regulator and a knob on the dashboard so now i control the blower speed manually.
greetings from Belgium,luc. |
