2000 STS License Plate Light Bulbs
Both light bulbs were burnt out so I replaced them with the correct bulb. When I put the new bulbs in, I checked to see ifthey worked prior to putting everything back together. Unfortunately, neither work. Any ideas? Is there a fuse that controls just these bulbs?
RE: 2000 STS License Plate Light Bulbs
Check for power and ground at socket, same fuse controls under hood light - see if it works. There is also connector in left corner of trunk lid.
Thanks slowroll; I'll check
