1999 Seville STS; Remove Shift Console Panel
Hello All,
E-mail not working well. Just wondering if anyone has had any experience in removing the gear shift console panel ? Looks like seven seperate tabs. Use a flat screwdriver ? Probably good to slide out toward rear of car. Thanks for your help. |
RE: 1999 Seville STS; Remove Shift Console Panel
quasi. ive had mine out twice before..... im thinking i removed console, cup holder first then was able to pop-up console panel from there. youll have heat seat switches to disconnect for panel to be removed.....good luck
rickyd |
How do you remove the cup holder and the faux wood panel in a 98 Seville STS to get to the interlock solenoid?
