1995 Seville SLS Heater Blower Motor
The Heater Blower Motor stopped working. Checked my manual to see what fuse controls this circuit but could not find which one it was. Everything had been working good with no strange noises (bearings) so I am thinking it is an electrical issue. Any help would be appreciated in trouble shooting this.
Thanks......Nick |
RE: 1995 Seville SLS Heater Blower Motor
i beleive the fuse is in the trunk on the left hand side, the fuses are labeled under the fuse cover,
good luck! |
If your fuse checks out ok, you might want to look at the connector to the blowwer motor itself.
Over time the connector gets hot and suffers from thermal expansion, meaning you lose good contact betweent the connector and the motor contacts, sometimes the blower will start working again for short periods of time then stop, this is a pretty sure sign of connector problems, the replacement connector kit cost about 27.00 from any good AC/Delco parts house part number PT779. Or worse case is the blower motor itself is bad, big bucks then and a royal pain to get in out. John |
