"Change engine oil" on display panel
my light came on and i already knew i needed an oil change so i changed the oil and the warning still comes up on the display panel. Is their any way to make it go away? if so please help!
RE: "Change engine oil" on display panel
I am guessing this 94 sls you made other posts about. With key on and engine not running press INFO button till OIL LIFE comes up. Then press and hold RESET button xxx will come up then 100 or RESET - now it's reset
