Eldorado steering column in Allanté?
Hello,
I read somewhere that the Allanté shared some parts with the Eldorado. Would anyone (hello Stealth!) know if it would be possible to put an Eldorado steering column in an Allanté? Thank you! |
column
Have the steering column with wheel and airbag from my parted '90 if anyone needs.
Originally Posted by MonteV
(Post 31774)
Hello,
I read somewhere that the Allanté shared some parts with the Eldorado. Would anyone (hello Stealth!) know if it would be possible to put an Eldorado steering column in an Allanté? Thank you! The Allante is a ElDo chasis, trimmed on its length. Will the steering column fit? That I dont know, it logically seems it would. I have not seen anything that tells me that the Allante had a unique steering system. I would check the compatibility parts lists that the salvage guys use or simply ask one of them. When it comes to using parts across different cars, they are the best at it. |
suggest Dick at Allantesource.com.
Thank you both for you knowledge and advice!
