Dropping Sun Visor
My passenger side visor is starting to droop. Is there an easy fix for this.
Bob |
RE: Dropping Sun Visor
Bob the easy fix is attaching a potato chip bag clip - $1. a 2d way is surgery to the visor, seems a few parts inside break and there you have the notorious fix with a clear tube that should last a couple of years - a weekend and a few $$$.. the 3rd way i know is the visor clutch that currently sells for about $80 each . |
the shaft that fails ... [IMG]local://upfiles/2893/A81BC9458C834DDC90D8001D008DC999.jpg[/IMG] |
the $80 clutch ... [IMG]local://upfiles/2893/FB50BFF9E0A442C5A6646A9E85D53328.jpg[/IMG] |
ORIGINAL: Stealth the $80 clutch ... [IMG]local://upfiles/2893/FB50BFF9E0A442C5A6646A9E85D53328.jpg[/IMG] |
Only problem with this one is the price...
I did find the photos of the hose fix on the "other" site. I might try that one Thanks Bob |
Bob, you did say "easy fix". |
also another way to fix the problem is to take them off and throw away and you will never have that problem again.
ORIGINAL: jono6406 also another way to fix the problem is to take them off and throw away and you will never have that problem again. |
My $2 fix takes 3 seconds. Got the potato bag clip in BLACK with RED handle.
Matches the liner and the red stripping well. Almost OEM. That other fix, the install a rubber tube, etc .. takes a full weekend, you hope nothing breaks in the process and you get about two seasons out of it? I either dont have the time or motivation. If the potato clip is good enough for zinzin, it is good enough for me. |
