Cadillac Forum - Enthusiast forums for Cadillac Owners (https://www.cadillacforum.com/forum/)
-   Cadillac PininFarina Allante (https://www.cadillacforum.com/forum/cadillac-pininfarina-allante-26/)
-   -   COOLING FANS (https://www.cadillacforum.com/forum/cadillac-pininfarina-allante-26/cooling-fans-2186/)
drew13 03-20-2007 12:11 PM
COOLING FANS
IS THE SYSTEM ON 93 ALLANTE [2 FANS 3 RELAYS] THE SAME ON ALL CADILLAC CARS WITH NORTHSTAR ENGINES
G.A.R.Y. 03-20-2007 09:37 PM
RE: COOLING FANS
My N* experience is related to the 93 allante only, however I will find someone here, or find the info myself to help you with your question.
Stealth 03-20-2007 09:47 PM
RE: COOLING FANS
w/o knowing the answer, i would get the PART #'s and get your local dealer
to cross reference them and see what other GM cars use it.
you can do the same on line with a GM parts house.
i assume you are looking for parts from other cadies that fit a '93?
if so, the local salvage yard has the cross references you would need.
ORIGINAL: drew13
Katzmans Caddy 03-21-2007 12:52 PM
RE: COOLING FANS
http://www.shop.com/op/~Dorman_Radia...91?xit_recnt=1
This parts listing shows interchangeabilty acrosss all lines from 93-2000.
acsnowrider 07-15-2012 07:32 PM
How about the 1992?? Diff/Same system???
Edwards0 11-06-2012 10:07 PM
Today i come back to this community and want to ask something special relating to your topic which is that I am trying to put cooling fans on the back of my enclosed entertainment center to help cool things off because the temperature is getting up to 145 degree fahrenheit. If anything can I get the schematic to build the cooling system myself from scratch.?Any Ideas which would be appreciated.
