Allante brakes
Old 05-21-2019, 07:19 AM
Steve1992's Avatar
Default Allante brakes
Has anyone had a brake leak problem where the e brake bracket bolts to the caliper?
Old 05-27-2019, 07:23 PM
Kixrock's Avatar
If you're leaking fluid at that spot you have no options but to replace the calipers,
Read up on replacing the rear shoes and making the interface with e brake. It
can be a little tricky. Good luck
screwdriver
Cadillac Allante 1987 to 1992 Phase I & II
05-19-2012 05:50 PM
cgmitch
01-10-2011 11:35 PM
dpv1977
11-06-2009 11:14 PM
01-02-2009 01:10 AM
FleetwoodFan
12-07-2008 04:21 PM
Quick Reply: Allante brakes
