Allante brakes
Has anyone had a brake leak problem where the e brake bracket bolts to the caliper?
If you're leaking fluid at that spot you have no options but to replace the calipers,
Read up on replacing the rear shoes and making the interface with e brake. It can be a little tricky. Good luck |
