interior lights stay on
My good friend has a 95 fleetwood and the interior lights will not turn off, so he has removed the fuse. What could it be???? Please help. Thanks
RE: interior lights stay on
Headlight switch rotated all the way to interior lights on? earlier GM cars would do this if tin foil or a dime etc were under a cigarette lighter, blows the 20 amp courtesy fuse, feeds back thru the dome lamp circuit and the lights stay on dimly.
Door jam switch malfunction. I just replaced one on my Suburban, $8 at the dealer.
i have a 94 fleetwood and had the same problem where my interior lights wouldnt go off. It ended up being a loose ground.
what ground?
Originally Posted by 1989 fleetwood
(Post 26089)
Lights stay on
Originally Posted by 89whitefleet
(Post 25628)
Do you have owners manual?
Ground
Someone said lights staying on ended up being a ground. Can you tell me what ground and where it is located?:(
Thanks so much for your help. |
Slowroll
Yes, I have an owners manual. But was unable to locate an interior light fuse.:confused:
This owners manual reads like a Manual for "Dummies" who have never been taught to drive. Talks about how to operate windows, how to put in gear what to do if going through high water, how to change fluids and put gas in, even how to clean it inside and out. But not a darn thing on interior light fuses.:( |
Originally Posted by Katzmans Caddy
(Post 26075)
Thanks Nick |
