What style is my 1963 Caddi?
I currently own a 1963 Cadillac something or other that is a 4 door 6 window sedan and I currently don't know whether it is a Sedan DeVille or a Fleetwood. The title says "Cad" "Fle" leading me to believe that it is a Fleetwood but I have heard from many sources that the Fleetwood model had power windows and locks and has a verticle post between the windows; none of which i have. Then i thought that it was a sedan DeVille but since the title doesn't say that plus I don't believe that the DeVille came with the power seats, which i have, and i do believe that the DeVille had the 6 seat belts where i have 2. If you have any info please let me know.
Thanks
Thanks
RE: What style is my 1963 Caddi?
No B-pillar in 1963.
There was, however, a Series-Sixty-Two Six-Window Sedan. If the two rearmost windows are attached to the doors (vent windows), then you have a Fleetwood Sixty Special. If you can get the data off the "body plate", the body style number tells you exactly what you have.
As far as Options are concerned, the standard set of options were bare minimum in the '60s, and you could pick-and-choose or delete any one of them. Seat belts were a dealer installed feature.
