Whirl Sound
Hello All!
Over the Weekend I had the joy of driving my inlaws Escalade SUV, smooth no big deal. I get home, hop into my EXT and as I accelerate I hear this "Clunk...Whirrrrrl.....Rrrrrrr" sound. What The? At a steady speed, no sound. Driving in trafficI hear it alot! I dont have mud tires on the truck, and you really only hear it while tapping on the gas pedal. I think all EXTs are AWD, is the system working or failing? Could it be the fuel injectors? Turn down your radios ans see if you hear this sound. It comes from the left side of the truck. Before I go "Vince McMahon-in" my local caddy service department I wanted to your advice. |
RE: Whirl Sound
bump
RE: Whirl Sound
What does that mean?
RE: Whirl Sound
Bump means someone wanted to get this back to the top so someone like slowroll or another tech could take a shot at the answer for you.
Whirl is a whine
For those who care, i think i may have forund out what my problem was. You may have the same problem and not know it. Check this out:
Whine Noise From Front Axle (Diagnose and Replace Front Propeller Shaft with a Tuned Internally Dampened Front Propeller Shaft) #03-04-17-005 - (Mar 13, 2003) Whine Noise from Front Axle (Diagnose and Replace Front Propeller Shaft with a Tuned Internally Dampened Front Propeller Shaft) 2002-2003 Cadillac Escalade, Escalade EXT 2000-2003 GMC Yukon Denali, Yukon XL Denali 2001 GMC Sierra C3 2002-2003 GMC Sierra Denali with AWD Transfer Case (RPO NP3 or NR3) Condition Some customers may comment on a slight whine noise from the front of the vehicle during light throttle conditions, typically at two vehicle speed ranges of 64-80 km/h (40-50 mph) and 112-129 km/h (70-80 mph). Cause "Inherent" ring and pinion gear whine. All gear driven units, such as automotive rear axles, produce some level of noise that cannot be eliminated with conventional adjustments and repairs. "Inherent" axle noise can be described as a slight noise heard only at a certain speed on most General Motorsฎ trucks. The presence of this noise is not indicative of a functional concern with the axle assembly. However, some customers may find that this "inherent" axle noise is unacceptable. Correction Replace the front propeller shaft with an internally tuned dampened shaft ONLY after diagnosis concludes that it is an "inherent" front axle noise and no physical damage or incorrect adjustment exists. Diagnostic Information and Procedure for Front Axle Noise Diagnostic Starting Point - Front Drive Axle (Refer to SI Do***ent ID #696970). Symptoms - Front Drive Axle (Refer to SI Do***ent ID #696957). Front Drive Axle Noises (Refer to SI Do***ent ID #700621). Noisy in Drive (Refer to SI Do***ent ID #700622). Noisy When Coasting (Refer to SI Do***ent ID #700624). Intermittent Noise (Refer to SI Do***ent ID #700625). Constant Noise (Refer to SI Do***ent ID #700631). Noisy on Turns (Refer to SI Do***ent ID #700634). Front Propeller Shaft Replacement Raise the vehicle. Refer to Lifting and Jacking the Vehicle (SI Do***ent ID #737171). Important: Before disassembly, observe and accurately mark all of the driveline components relative to the propeller shaft and to the axles. These items include the following components: The propeller shafts The wheel drive shafts The pinion flanges The output shafts Assemble all of the components in the exact relationship to each other prior to removal. Observe all published specifications and torque values and any measurements obtained prior to disassembly. Remove the transfer case shield, if equipped. Remove the clamp (if applicable) (4) at the transfer case (3) by prying up the exposed end of the clamp (4) with a flat-bladed tool. Remove the bolts (6) and the yoke retainers (7) from the front axle pinion yoke (1). Notice: When removing the propeller shaft, do not attempt to remove the shaft by pounding on the yoke ears or using a tool between the yoke and the universal joint. If the propeller shaft is removed by using such means, the injection joints may fracture and lead to premature failure of the joint. Disconnect the propeller shaft (2) from the front axle pinion yoke (1). Remove the propeller shaft (5) from the transfer case output shaft by sliding the propeller shaft forward. Inspect the splines of the transfer case output shaft for a sufficient coating of lubricant. If the output shaft does not have a sufficient coating of lubricant, lubricate the shaft with lubricant, P/N 12345879 (Canadian P/N 10953511), or with an equivalent lubricant meeting GM specification 9985830. Important: Some old driveshaft boots may only use a single clamp design. When installing the new propeller shaft, use ONLY a two clamp boot. Install the new clamp, P/N 26064275, supplied with the new propeller shaft, P/N 15186002, into the groove of the propeller shaft boot. Install the propeller shaft splines into the transfer case output shaft. Install the propeller shaft to the front axle pinion yoke. Install the yoke retainers and the bolts. Tighten Tighten the yoke retainer bolts to 25 Nm (19 lb ft). Install the boot onto the transfer case output shaft until the boot is attached into the groove on the output shaft. Using the J 43218 , crimp the clamp until the dimensions that are shown are obtained. Install the transfer case shield, if equipped. Install the transfer case shield mounting bolts, if equipped. Tighten Tighten the transfer case shield mounting bolts to 20 Nm (15 lb ft). Lower the vehicle. Parts Information Parts are in limited quantities. DO NOT order parts for stock. Part Number Description Qty 15186002 Propeller Shaft, Front 1 Parts are currently available from GMSPO. Warranty Information For vehicles repaired under warranty, use: Labor Operation Description Labor Time F1200 Propeller Shaft, Front Of Transfer Case - Replace Use published labor operation time GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION ฉ Copyright General Motors Corporation. All Rights Reserved. |
