Vacuum line missing?
Old 10-03-2018, 09:12 PM
BlownDSG's Avatar
Default Vacuum line missing?
Hi,
My buddy has a 2008 Escalade with the 6.2l. He brought it to me saying it was idling low and it was throwing some codes. Replace the crank positioning sensor and cleaned out the throttle body. Cleared the codes and did the throttle body relearn. It still idled low and then it threw a bank 1 lean code. Started looking around for vacuum leaks and found an open vacuum line on the passenger side mid way back on the intake manifold. I looked around and could not find any loose lines. So my question is, is there supposed to be a plug on this port or has a hose fallen off? It pulls vacuum when running so for now I put a plug on it and it seems to run ok. It idles at 600-620 ish. I'm not sure where this thing should idle. Anyways, any help would be appreciated. Thanks in advance!!
Old 10-09-2018, 07:53 PM
BlownDSG's Avatar
Old 10-11-2018, 12:24 AM
BlownDSG's Avatar
Anyone??
el_dorado_mex
Aluminum Block V8s
07-24-2012 04:44 PM
sbrice54
07-18-2009 09:55 PM
clampet
01-15-2009 09:29 PM
trx100
08-12-2008 08:46 PM
fleetwoodmack
09-02-2006 07:56 PM
Quick Reply: Vacuum line missing?
