Can new OEM 22"s fit on a 04 Lade??
Does anyone know if it is possible to put the new oem 22" on an 2004 escalade? I love the stock 22 look on the 07's. Thanks for your input!
RE: Can new OEM 22"s fit on a 04 Lade??
Yes, although the official word from GM is not recommended.I would check for tire rub up front when turning.Hope it helps
thanks! do you think I will need to disable the tire pressure sensors? or do you think they will also work?
Not sure on compatiblity for 04 to 07,you may have to use 04 sensors but TPM really doesn't care what size wheel you have it just looking for a signal from it.Hope it helps
I run the 22's on my 02
